Is there a way to Monitor instance without accessing the data?
Akshay Pande
Hi @Akshay Pande ,
You can attain this indirectly via email notifications or a limited role access to the dashboard.
You can automate sending mail notification or directly create records based on threshold breach using flows. (Ex: if SLA breaches 90% create an notification to X team and Create a task record to X team).
Or
Create a dashboard and reports which can be accessed with limited role and provide read-only access to all the modules. (Without login email is the only way you can view reports, bcoz the data , reports, dashboard may need certain roles to access them post login)
I hope this helps
☑️ Please mark responses as HELPFUL or ACCEPT SOLUTION to assist future users in finding the right solution....
LinkedIn - Lets Connect
Hi @Akshay Pande ,
Or
I hope this helps
cosek
How to monitor EC2 instances by memory?
