Issue parsing powershell output
vdeshpande
Kilo Explorer
I am working on a Exchange integration using Orchestration. we have a custom powershell script
Output is showing as below
WARNING: The names of some imported commands from the module 'Exchange' include
unapproved verbs that might make them less discoverable. To find the commands
with unapproved verbs, run the Import-Module command again with the Verbose
parameter. For a list of approved verbs, type Get-Verb.
Deshpande, Amruta
1.   - How do I get rid of the WARNING message
2. How do I parse only last line ignoring warning message
Thank you
Hi Varsha,
If you are importing exchange module, then your synyax would be
import-module -moduleName           - DisableNameChecking
This worked Deepak , thanks a lot !!
staceyrocheleau
Since you're using exchange, are you setting up a pssession?
This link might be useful to you in where to set the flag:
powershell - Suppress output from Import-PSSession - Stack Overflow
