Lab 6.17: Create Connection Section to PostgreSQL
chrisj2
I cannot get this lab to validate. The error is below when I try to run the command that I copied and pasted directly from the lab material. I am using http://198.51.7.33:8080/ticket-monster but is says it doesn't work. I passed the rest of the course and completed the quiz but I'm not getting verification that I passed the course and I think it's this one thing.
If anyone has some advice, please help.
Thank you!
Sandeep Rajput
@chrisj2 Please raise a case with Now Learning support team. Only they will be able to help you in this case.
9 REPLIES 9
Meerim J
also the same issue
Meerim J
There is no hints, which data to use for debugging this task. Is it : http://198.51.7.33:5432/ticket-monster ? also should we provide Directory and host name?
J_rg Matz
I'm facing the same issue, the last step cannot be finished.
I analyzed the situation. The find command we are asked to issue will fail, because the temp directory we are using is a symlink. The find command does not by default follow symlinks. The failure can be remediated by using the "find -L" option. This will return the correct file name for the config file. But changing the command will in the end cause the lab validation to fail.
After trying to reproduce, the find command suddenly works, even without the -L option. Don't know what happened.
iamasifk
Here is the solution:
Configure Debug Mode as follows:
Entry point for JBoss WildFly
- Select Entry Point Type: HTTP(S) Endpoint
- URL: http://192.168.7.31:8080/ticket-monster
Entry point for Identification for JBoss WildFly Module
- Select Entry Point Type: JBoss WildFly Module Entry Point
- Directory: /opt/wildfly/standalone/tmp/vfs
- Port or Host: <empty>
- Name: ticket-monster
