Map Suppurt Group Change Group and Managed By Group using the excel file that has CI Class name
I am trying to Map Support Group, Change Group and Managed By Group using the excel file that has CI Class name and corresponding Managed by Group, Support Group, Change Group.
I tried to load the data from excel file using import set and when trying to run Transform Map, not able to find the "Class" in Target field of CMDB_CI.
I tried to create a custom column sys_class_name but it is not mapping correctly.
Please suggest.
CSV Column ServiceNow Field (cmdb_ci)
Classsys_class_name (Class)
Managed By Groupmanaged_by
Support Groupsupport_group
Change Groupchange_group
Filtered URLreference_url
Hi @Community Alums ,
I will get back to you as soon as I can.
Thank you,
Selva Arun
Hi @Selva Arun
Kindly let me know if you were able to figure out the solution.
Hashim
