Mid Web services extension listener is not starting
01-14-2024 11:15 PM
Mid server extension event listener is struck with starting status , it should be in started
any idea why its struck with starting? it seems it been a day in same status
Event Management
03-04-2024 11:37 PM - edited 03-04-2024 11:38 PM
Looking at your issue , seems to be user doesnt have mid server role or the user is locked out
Check local user mid.ACC-DMMY-1
We found network firewall blocks to communicate monitoring source .
eventlisterner port and web url not accessing through mid-server
SO, check with device team first to confirm firewall access
03-04-2024 11:48 PM
Thx, seems we have two different issues. 😉 The MID server is working quite a while (with MID user + correct role and not locked out), the web service is stucked in starting just after upgrade or when you provide new JAR file for MID (which will restart hte MID itself). Hopefully it will not appear again. 😉
03-06-2024 12:58 AM
Same Issue as we faced after upgrade ... its firewall blocks from mid server to monitoring source
its blocking following ports "8075 OR 8076"
Check device team to allow both ports in mid server , then issue should fix
