Missing pattern-based outgoing connections from load balancer. Please check the correctness of the incoming connection
pavanyuvi
We are getting the below issue
"Missing pattern-based outgoing connections from load balancer. Please check the correctness of the incoming connection"
only loadbalancer information is populating,please find the attached image.
In discovery log it is showing it is taking as "citrix netscaler pattern",Identification is running fine but in connections
Executing SSH command: show vserver | grep ciname
2018-09-24 11:48:29: Executing SSH command: command -v sudo
2018-09-24 11:48:42: Command result: ERROR: No such command
2018-09-24 11:48:46: Command result: Warning: Feature(s) not enabled [GSLB]
2018-09-24 11:48:46: Execution time: 16956 ms
get policies rules and actions relations
2018-09-24 11:48:46: Step condition is false. step not executed.
2018-09-24 11:48:46: Execution time: 0 ms
get our vip policies
keep all relevant rules
keep policies matching our port or not matching on port
get all actions
merge actions and actions name
extract vservers from actions
get vserver info
extract members and ports
 Create connection
verify no connections
filter out all connections with non operational status and without ip address
keep all connections with port 0 empty * or null on seperate table
remove all connections with port 0 empty * or null on seperate table
replace empty ports with real ports
union both tables
2018-09-24 11:48:46: setAttribute(connections,[])
Create connection
Pavan
This is not helping. Any other solution ?
