Need help to build a script to divide two integer fields
giovanni3
How do you divide two integer fields to get a value in a separate field?   For example, field1=10, field2=5.   I want to divide field1 from field2 and have the value in field3.
11 REPLIES 11
var StartNumber = '444,555,666';
var ReplacedNumber = StartNumber.replace(/\,/g,'');
document.write(ReplacedNumber);
The above shows how a regular expression can be used in JavaScript to remove the commas.
giovanni3
I did change the field C from integer to decimal.
giovanni3
I also tried changing field A and B from integer to decimal but it made no difference.
giovanni3
Hi Tim,
Forgive me but I cannot program in javascript!   Do I add that to the onload script?   If so, what lines should I add them in?   Below is the onload client script...
function onLoad() {
    //do nothing, just loading the function below
function divide_a_by_b() {
      var a = parseInt(g_form.getValue('u_total_test_count___ca'),10);
      var b = parseInt(g_form.getValue('u_total_req_count___ca'),10);
      var result = 0; // force to zero if infinite
      if (b != 0) {
              var result = (a/b).toFixed(2);
      g_form.setValue('u_avg_test_req_count___ca',result);
Try:
function onLoad() {
      var first = g_form.getValue('u_total_test_count___ca');
      first = first.replace(/\,/g,'');
      var second = g_form.getValue('u_total_req_count___ca');
      second = second.replace(/\,/g,'');
      var a = parseInt(first,10);
      var b = parseInt(second,10);
      if (b != 0) {
Hopefully my cutting and pasting didn't break something.   I don't know that you still need to do the parseInt.
