Need help with the Discovery Fundamentals on Create iTunes Discovery Pattern (Part 2)
I need help with the Discovery Fundamentals on Create iTunes Discovery Pattern (Part 2),
I am getting error Did you check the steps in the identification section are configured and tested correctly even though I have tried all the ways.
Can someone please guide, I am attaching the screenshots, please let me know if you need any other information
hanwar2_0-1736256058956.pnghanwar2_1-1736256080562.pnghanwar2_2-1736256096797.pnghanwar2_3-1736256112603.pnghanwar2_4-1736256132720.png
I was able to figure out and task got completed.
hanwar2_0-1736259160368.pnghanwar2_1-1736259179625.pnghanwar2_2-1736259198142.pnghanwar2_3-1736259217271.pnghanwar2_4-1736259236735.png
9 REPLIES 9
Jay80
i need help for above please.
is the above selection correct? when i try to connect iam getting error, also Guided Mode is always greyed out and i cant see the advanced mode.
Shan2311
Unable tp navigate
  • After discovery completes, open the discovered iTunes application and confirm the Name, Version, and Description field are populated as configured in the iTunes pattern.
I am stuck on step 5.  Everything tested successfully and showed the version populated.  I then saved and published.  Synced the pattern to the mid server, ran discovery but then when checking the iTunes application the version field is empty.  What am I doing wrong?
similar issue was happening to me as well, everything was configured as mentioned, i raised a 'hi' ticket and put the screenshot of the issue, apparently there was an issue in the backend on the midserver, and they closed the simulation task from there end and the task got validated automatically.
Hmm I would say make sure that you type version in lower case in the Name field for your step 5. So it should look like this $cmdb_ci_appl[1].version in the Name field
