No shell detected and probe parameter 'allow_unsupported_shells' is set to 'false
VPN
I tried discovery on linux box to discover applications and DB' installed on it.
I am getting an error
"No shell detected and probe parameter 'allow_unsupported_shells' is set to 'false"
Where to check these parameters is set to false or not.
11 REPLIES 11
dileeppeddi1991
Hi Marlos,
i have created the probe parameter as below.
after adding this am getting another error.
i have created probe parameter for UNIX-OS .but even though am getting the same error which i have mentioned above. can you please help me on this.
thanks
kuamr
Timothy Brown
Mega Expert
I have discovered with this message, if the server was being discovered the password has expired.
Most likely the credentials on the server has not been setup correctly. I would contact your Linux Admin and have them verify the credentials you are using have been setup correctly.
Tim Brown
