What is the difference between REQ, RITM and tasks?
gunishi
Hi there,
I am struggling with the difference between REQ records, RITM records and STASK records.
The thing that is stumping me the most is which is referenced when I am using workflows. When I use a run script activity and type current.variables.name_of_variable what does current reference? Is it the overall request, is it the RITM, or a task that this is referring to?
I'm asking because I have a lot of variables on the CI order form that I would like to access. So if the user picked a choice of lettuce, I want to create a task that has a short description 'Vegetable - Lettuce'. I am struggling to understand the workflows a lot and also how would I then referene the RITM if this is for the request?
Any help would be much appreicated. Thank you.
Kind regards,
G
3 ACCEPTED SOLUTIONS
Anurag Tripathi
Giga Patron
Best way to think of this is as below:
Imagine your Amazon or any other shopping cart
Request -> This is your order ID, this may contain several items you have ordered.
Requested Item -> This is the individual item, One request may contain multiple request Items
SC Task -> This is the individual task that needs to be don't to fulfill each Requested item, like shipping, packaging etc. This is for typically for the fulfiller teams.
In your workfow script current would the table workflow is written on (Most likely requested item)
-Anurag
Jaspal Singh
Mega Patron
So, in simple terms you can relate it to online shopping where
REQ - is your Order number (1 Order number for 10 items ordered suppose)
RITM - is number for each item ordered (10 separate items/products ordered)
SCTask - Delivery time for each RITM (10 products to be delivered by different delivery companies)
For every REQ there will be a corresponding RITM in ServiceNow OOB but having an SCTask for RITM is optional.
Now, coming on the 'current' is current record that is submitted. Now, it is REQ or RITM will totally depend on the table workflow is being called. You can check the Properties for the particular table. If it is RITM table then current will be RITM record and if it is REQ it will be REQ record.
Peter Bodelier
Hi @gunishi,
I always try to explain it as this:
The Request can be seen as your shopping bag, it contains everything you have bought.
The RITMS are the items in your shopping bag which you bought.
The sc_tasks are the tasks for the supplier to be able to package your items, and send them to you.
For your workflow I think you are mentioning the workflow which is defined in the Catalog Item?
If so, current is your RITM.
Help others to find a correct solution by marking the appropriate response as accepted solution and helpful.
9 REPLIES 9
No, it if the tabel is sc_request then it will be REQ and not RITM.
Hi @Jaspal Singh @Anurag Tripathi
That's great, thank you so much. So I have to specify the RITM table to access the variables that were on the original CI form?
So sorry for all the questions; workflow is the part of ServiceNow I am struggling with the most, and I really appreciate all the help.
Kind regards,
G
Yes so you need to write a GlideRecord query to find the RITM , and then you can use gr.variables.name_of_variable to access the variable.
gr being the gliderecord object
-Anurag
Peter Bodelier
Hi @gunishi,
gunishi
Hi @Peter Bodelier @Jaspal Singh @Anurag Tripathi
Thank you so much for your help, this has really cleared up some questions for me.
Kind regards,
G
