Access control help
I've created a "READ" access control which has worked...ish. For some reason its now showing a blank placeholder where the record should be, any ideas how I can just remove this completely?
I did try and configure it instead however the dynamic "is one of my groups" didnt seem to work so had to go down the scripting route.
Script condition
answer = true;
if (current.u_nda) {
	var group = current.u_authorized_group;
	if (!gs.getUser().isMemberOf(group)) {
		answer = false;
Hey all, I managed to get it working using "addEncodedQuery()" which is actually really simple.
//When to run: Before
//Order: 1000
// Query: True
(function executeRule(current, previous) {
    var query = '';
    query = "u_authorized_groupDYNAMICd6435e965f510100a9ad2572f2b47744^ORu_authorized_groupISEMPTY";
    current.addEncodedQuery(query);
})(current, previous);
Thank you everyone for your help!
14 REPLIES 14
Hi, I tried None but didnt work. And I also tried the script you provided however it just hid all the records not just the ones which I'm trying to filter out.
@Community Alums
try this
    // Add your code here
    var groups = new global.ArrayUtil().convertArray(gs.getUser().getMyGroups());
    current.addEncodedQuery('u_nda=true^u_authorized_groupNOT IN' + groups).addOrCondition('u_nda', false);
Runjay Patel
Hi @Community Alums ,
Why are you giving table.*? are you trying to hide all fields on project table if conditions matches? if not and trying to provide read access at record level then you should use table.none.
Hi all, I think I'm onto something.
After reading Dynamic filter 'One of My Groups' does not work for Glide List type field with more than one item - ... apparently "One of my groups" is basically worthless in ACL and Data filtration.
So I went down the BS route, this script works perfectly where if the user is IN the group it hides the record but I need it to do the opposite, I've tried NOT IN however nothing happens.
(function executeRule(current, gsn) {
    var usergroups = [];
    var groupgr = new GlideRecord('sys_user_grmember');
    groupgr.addQuery('user', gs.getUserID());
    groupgr.query();
    while (groupgr.next()) {
        usergroups.push(groupgr.group.toString());
    current.addQuery('u_authorized_group', 'IN', usergroups);
})(current, gsn);
//Order: 1000
// Query: True
    var query = '';
