Acl problem
robertpetrovics
Hi guys! I need to give read only access for two roles that I created to a certain table, but it seems that some fields are missing altough I gave the roles read to all fields from that table( see ACL in attachement). What should I do? there a other ACLs for other roles set up for specific fields on this table, are those ACL's in conflict with mine? Some of those other ACL's are even in a different application, should I create an * ACL for every application?
Sohail Khilji
Hi @robertpetrovics ,
You ACL in screenshot looks fine, The reason  why some of the fields are still visible is because of there must be other ACL on those fields which are allowing access. You need to update those ACLs with These 2 roles and you must be good to go...
☑️ Please mark responses as HELPFUL or ACCEPT SOLUTION to assist future users in finding the right solution....
LinkedIn - Lets Connect
