Using a PDI for familiarization of OTB ServiceNOW ITSM configuration
cviray
I'm trying to learn the out of the box configuration of the ITSM modules from ServiceNOW (Request, Incident, Change, and Problem). Incident and Request (which are covered within the Admin Fundamentals course pretty well) are fine, but when trying to follow Problem Service NOW courses, I'm not seeing the options it guides me thru. For Example, there's no "Additional Action" option to create a Problem from an incident in my PDI. This makes me wonder what ITSM modules come activated within a PDI. Does anyone know if PDI's come with the full OTB ITSM suite from ServiceNOW? Would I be able to add/activate options in my PDI to get to my goal of learning the OTB config of ServiceNOW ITSM modules?
Problem Course: Problem Management: Next Experience - ServiceNow University
Tanushree Maiti
Hi @cviray
If the "Create Problem" option is missing from the Additional Actions menu on an Incident in your Personal Developer Instance (PDI), the Problem Management plugin (com.snc.problem) is likely not activated.
To fix this, log in as admin, navigate to Plugins, search for "Problem Management," and activate it, ensuring "Load demo data" is checked if you want to explore sample records.
Note: If it is installed already , Repair the plugin and try
Tanushree Maiti
Dr Atul - LNG
Hi @cviray
This issue is coming because the PDI is in a bad state. It looks like the Change and Problem modules are missing. The best option is to release this PDI and request a new one.
