Add a Phone number field. It should accept 10 digits (numeric) and can't be left alone.
gouthamsainallu
Hii
        Can you please tell me how can I do this.
Hii,
        Thank you for ur reply actually in incident I didnt find the variable field so can you please tell me how can i do...by providing any screenshots.
Hi Goutham,
Did you get your answer by my reply
preddy
Hi Goutham,
Use the below Code in Onchange Client script.
      if(!isLoading){
              var val = newValue;
              var achar = '0123456789.';
              var failmsg = 'This Field Should Allow the Numeric value.';
              var array1 = val.toLowerCase().split('');
              for (var i=0; i < array1.length; i++){
                      if (achar.indexOf(array1[i]) >= '0'){
                      else{
                              alert(failmsg);
                              g_form.setValue('field name', '');
Ple hit/Like if this is helpful for you
Sampath8
Please try the below OnChange client script.
if(isLoading || newValue == ''){
var pattern = /^[0-9]*$/;
if(!pattern.test(newValue) || (newValue.length <= 9) )
alert('please enter only digits and min length should be 10 ');
g_form.setValue('field_name', ''); // adjust field name accordingly if you want to blank it out.
Lrt me know if any concerns.
Sampath.
THANKS bro its working
