Adding a field to problem form which is available on incident form
‎08-08-2022 04:35 AM
Hi Team,
I have one requirement to add a field which is currently available in incident form to add in problem form.
That is a field named 'Abc' currently available in incident form. I need to add the field 'Abc' to problem form.
Could any one please suggest on this.
‎08-08-2022 05:00 AM
‎08-08-2022 04:40 AM
Do not want to repeat what Mark has said but want to add one thing, If there is a reference to Incident table on Problem record then you can dot walk Incident table and bring that field on Problem form easily.
‎08-08-2022 04:53 AM
Thanks Musab for your response. Could you please explain once?
‎08-08-2022 07:19 AM
I see there is no direct relation between problem and Incident on Problem form , there are fields like 'First reported by' but it is referring to task table hence I suggest you directly create a field on Problem table.
Mark my answer as correct if that helps
‎08-08-2022 07:51 AM
Thanks Musab. I am also think so.
