Adding field in Tech assist portal
Abishek1998
Hi all,
I want to add a Employee number field in the work details section which is available in the my profile of service Portal.
I tried adding a field in work details section from sn_employee_overview_section TABLE. But still the changes are not reflecting in portal?
I have attached the image.
alexalejandro
@Abishek1998 Have you tried to edit the widget directly in the portal? Maybe using page designer will help.
Find the widget used (commonly something like):
  • User Profile
  • Employee Profile
  • or a custom clone
Check the widget’s HTML / server script
Look for something like:
data.user = $sp.getUserRecord();
or:
data.user = {
  department: user.department,
  title: user.title
// specific
👉 If it’s the second case, your field is NOT included automatically.
add your field to the server script:
data.user.employee_number = user.employee_number;
Then, also update the HTML:
<div>
  <label>Employee Number</label>
  <span>{{data.user.employee_number}}</span>
</div>
If it is using $sp.getUserRecord()
Then the issue is usually:
  • The field is not on the sys_user table
  • OR it’s not readable due to ACLs
Check:
  • Is your employee number field actually on sys_user?
  • Does it have read access for the logged-in user?
alexalejandro
  • User Profile
  • Employee Profile
  • or a custom clone
or:
data.user = {
  title: user.title
// specific
<div>
</div>
Check:
