Alternative for DOM Manipulation in client script
kavitha_cr
Mega Guru
I am using the below code in a Onsubmit catalog client script to show an alert for attaching a file before submitting the ticket in the portal.
Script:
function onSubmit() {
try { //Works in non-portal ui
var attachments = document.getElementById('header_attachment_list_label'); //Line3
if (attachments.style.visibility == 'hidden' || attachments.style.display == 'none' ) {
alert("Please attach file before submitting.");
return false;
} catch(e) { //For Service Portal
var count = getSCAttachmentCount();
if(count <= 0) {
return false;
According to Best Practice, we will not be using DOM manipulation , so I need to replace the code. Can I get the alternative solution for the line 3 in the above script by not breaking the existing functionality.
Thanks in Advance,
Shilpa.
I haven't tried with this
let us know if that works well
var attachments = g_form.getFormElement('header_attachment_list_label');
21 REPLIES 21
Hi Aman,
Thanks for the response. But
document.getElementsByClassName
is also a DOM method. Please let me know the replacement of the code other than the DOM methods.
Shilpa.
Glad that my blog has helped.
I hope you must have marked it as helpful and also bookmarked it.
Hi Ankur,
Shilpa.
Hi @Ankur Bawiskar ,
Can I use the below code as the alternative for line
Exisiting : var attachments = document.getElementById('header_attachment_list_label');\\ used DOM
Modified code with out DOM : var attachments = g_form.getFormElement('header_attachment_list_label');
Can you please guide me if I can replace the above sentence.
Thanks in advance,
Shilpa.
