Alternative for DOM Manipulation in client script
kavitha_cr
Mega Guru
I am using the below code in a Onsubmit catalog client script to show an alert for attaching a file before submitting the ticket in the portal.
Script:
function onSubmit() {
try { //Works in non-portal ui
var attachments = document.getElementById('header_attachment_list_label'); //Line3
if (attachments.style.visibility == 'hidden' || attachments.style.display == 'none' ) {
alert("Please attach file before submitting.");
return false;
} catch(e) { //For Service Portal
var count = getSCAttachmentCount();
if(count <= 0) {
return false;
According to Best Practice, we will not be using DOM manipulation , so I need to replace the code. Can I get the alternative solution for the line 3 in the above script by not breaking the existing functionality.
Thanks in Advance,
Shilpa.
I haven't tried with this
let us know if that works well
var attachments = g_form.getFormElement('header_attachment_list_label');
20 REPLIES 20
Did u find alternative code from Dom manipulation to standard ServiceNow api?
