Assignment group read only
DSV22
Hi Team,
I have to make assignment group (which is mandatory) read only, based on the a choice field and the roles of a user i.e..,
I have field named "desk" with 3 choices "it", "hr", "dat entry" and the field will be populated with "it" when the form loads, I have to make assignment group read only when the "desk is "it" and assignment group should be editable by Admin and itil admin users. When users select another choice of the field
I have tried using ui policies and client script but not working, can anyone help me out to achieve this.
Thanks in advance
Runjay Patel
Hi @DSV22 ,
You can create onchange client script.
use below code, i have tested it. working as expected.
	 var role = g_user.hasRole('itil_admin');
        if (newValue == 'it') {
        if (!role) {
            g_form.setReadOnly('assignment_group', true);
        } else
            g_form.setReadOnly('assignment_group', false);
    } else
        if (!role) {
        } else
    } else
Assignment group is read only for ITIL user.
Note: If assignment group is mandatory in your case then before making readonly you need to first make it non mandatory.
HI @Runjay Patel ,
your solution had worked in making the assignment group read only but making it mandatory for other choices is not working i have done exactly what you mentioned in the note.
Hi @DSV22 ,
Use below code to make mandatory if Desk not selected as IT.
        if (!role) {
        } else
    } else
        if (!role) {
        } else
    } else{
g_form.setMandatory('assignment_group', true);
one line of code you need add.
