Assignment Group should be populate based on Caller Group
Vamsi26
Hello Everyone,
I am having requirement as if the Caller user is a member of "SNOW-L1-USERS" group then the incident should be automatically assigned to "SNOW-L2-USERS" group.
Can you please help me how can i achieve this.
Thanks 🙂
shloke04
Please follow the steps below to achieve your requirement:
Below is a tested method and works correctly in my PDI for both on Change and On Load of your Caller value on Incident or any other form you want.
1) Create a Display Business Rule on your Table where the caller field is present , I am considering it is present on Incident table. So, below need to be implemented:
BR:
Type: Display
Table: Incident:
Script:
	// Add your code here
	var getCaller = current.getValue('caller_id'); // Replace "caller_id" with your caller field
	var gr = new GlideRecord('sys_user_grmember_list');
	gr.addQuery('user',getCaller);
	gr.addQuery('group','groupSYSID here'); // pass the Sys id of group "SNOW-L1-USERS"
	if(gr.next()){
		g_scratchpad.isMember = true;
	}else{
		g_scratchpad.isMember = false;
})(current, previous);
Now write an On Change Client Script on Incident Table and use the script as below:
        if (g_scratchpad.isMember == true) {
            g_form.setValue('assignment_group', g_scratchpad.GroupID);
    if (newValue && g_scratchpad.isMember == true) {
Shloke
Shloke
Anmol8
Mega Guru
1. You have to write the script include non client callable and write script so that it fetches user from that particular group.
2. Add reference qualifier on the user field. for example - javascript:new myScriptInclude().my_refqual().
Please refer the code to get the users from groups.
Now for the new incident.
1. Create a business rule .
2. Which runs on condition if the user is memberof that group, you can create new record on incident table and set the assignment group field with the required sysid of group you need.
Please mark helpful and correct if applicable.
getGroupUsers : function(groupId)
		var usersArr = [];
		var groupMembers = new GlideRecord('sys_user_grmember');
		if(groupId !='')
		groupMembers.addQuery('group',groupId);
		groupMembers.query();
		while(groupMembers.next())
			usersArr.push(groupMembers.user.sys_id.toString());
		return 'sys_idIN' + usersArr.toString();
shloke04
BR:
Type: Display
Table: Incident:
Script:
	if(gr.next()){
	}else{
Shloke
Shloke
shloke04
Hi Vamsi,
If your query is resolved, can you please mark the answer as correct and close this thread for others.
Shloke
Shloke
adnanhaider
Why Caller ID show more User then Assignment to?
