ATF Failure in scoped applications.
srikanthmee
Hello All,
 I've created an ATF for a scoped application in my dev environment, It was running fine and I moved it to test. TI cloned back Dev from TEST. Then 'run server side' step in the test giving me an error.
Basically, I am submitting a record producer and it will create a record in a table and also creates an RITM, I am trying to open the record submitted and open a field having "i" icon. Below is the error code.
Test failed due to JavaScript error executing step:
JavaException: com.glide.script.fencing.CrossScopeAccessNotAllowedException: Access to Step.sibling from scope x_gdot_pir_scope not allowed
at:21
Full logging from step execution:
15:52:37.534 Loading script: jasmine_lib/jasmine31.js
15:52:37.737 Successfully loaded jasmine_lib/jasmine31.js
15:54:07.738 Security restricted: Execute operation on API 'Step.sibling' from scope 'PIR Scope Document' was denied. The application 'PIR Scope Document' must declare
my run script test has the below code in it.
did anyone faced this?
laszloballa
Administrator
As a result of the cloning, your cross-scope privileges got revoked / removed. Try this:
  1. Switch to the 'x_gdot_pir_scope' appliation (scope)
  2. Go to 'Application Cross-Scope Access' menu (or sys_scope_privilege.list)
  3. Create a new record:
    • Source Scope: should be set automatically to PIR Scope
    • Target Scope: Global
    • Target Name: Step.sibling
    • Target Type: Scriptable
    • Operation: Execute API
    • Status: Allowed
Run the test again. If any other APIs fail, repeat the process above for those too.
That worked, Thanks @laszloballa
