ATF, Not able to submit the Record Producer
06-24-2019 09:01 AM
Hello Everyone,
I am facing an issue while writing a test case using ATF module on Service catalog(Record Producer).
I wrote a test case on record producer with 3 test steps
1) Open the record producer
2) Set Variable values
3) Close the record Producer. Here I am getting the error when I tried to run the test case and it is getting failure. As I am new to ATF module not able to find the issue.
Could please someone let me know if the same issue occurs to you.
Thanks in Advance
Sreedhar
Service Catalog
11-06-2019 02:28 AM
Hi Sreedhar,
Any update on this issue?
Did you get the resolution for this?
06-24-2019 10:11 AM
Also just found this KB article which sounds like a similar issue based on your screen shots:
https://hi.service-now.com/kb_view.do?sysparm_article=KB0656139
10-12-2023 05:03 AM
Hi @Sreedhar3
I found 2 KB article, this could help:
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0831472
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0656139
Shaqeel
