Auto close changes records
01-19-2026 05:49 AM
Hi Team,
Here is my use case:
Need some suggestions to implemented this, I know we do it via scheduled script. is there any other way to achieve this using flow designer. not familiar with flows
Give some suggestions
Change Management
01-19-2026 07:14 AM
This is not a good approach, especially from a change management perspective. A change should not be automatically closed immediately; it should only be closed after the Review state is completed. The reason is that the change must go through the PIR process.
Also, what happens if an agent fails to update the state of a change even though the change was implemented successfully? And what about changes that look successful on paper, but fail in reality? Are we going to revert those even though the change was marked as unsuccessful?
There are many open points here. We should first focus on defining and fixing the process. Once the process is clearly set up, then we can move forward with a technical solution.
01-19-2026 07:49 AM
Thanks, Atul.
I had the same concerns. If the planned end date has passed while the state remains Implement, we should exclude that change record, assuming the assignee has not taken action.
01-19-2026 07:52 AM
Hi @Akhil32
Marking the change as unsuccessful is not the solution here. This is a process question first, my friend. Once the process is clearly defined, the platform can support it much better.
01-19-2026 07:48 AM
approach using flow is already shared by @tiagomacul
please try that and share us feedback
