Auto Close Incident after 5 days of resolution only for P1/P2
04-13-2026 07:51 PM
Currently incident is auto-closed after 3 days of resolution in ServiceNow. Want to know if it is technically feasible to have a 5 days auto-closure set only for P1/P2 incidents and not for all.
There is OOO system property ''glide.ui.autoclose.time" (attaching the screenshot for reference). This property is not set for any specific priority.
04-13-2026 11:30 PM
HI @Sanika , You can do this with help of a schedule job, to check if incident of p1/p2 is resolved before 5 days ago, the state should be updated to closed.
Make a schedule job to run daily basis, glide to inc table using schedule job script.
Here is a demo script -
gr.addEncodedQuery('priorityIN1,2^resolved_atRELATIVELT@dayofweek@ago@5^state=6'); //modify query according to requirement.
while (gr.next()) {
gr.state = 7; //
//update other fields according to you.
gr.update();
If this response helped resolve your issue or question, please consider marking it as Accepted Solution and giving it a 👍.This helps others in the community find useful answers more easily.
Saurabh V.
