Auto generate ID with numbering startig from 101, 102, 103
Rachel39
Hi Experts,
I have a custom table name u_org_hierarchy with columns having ID, Name etc.
Requirement: Auto generate the ID field whenever a new record is inserted in the table u_org_hierarchy and if the last record is 105 so the new record should be generated as 106 in ID field.
Could you please help me achieve this by business rule.
Checkout the screenshot, ID field should be generated as starting with 101 and next record should be 102
2 ACCEPTED SOLUTIONS
Samaksh Wani
Hello @Rachel39
Go to Table > you can check for related tab and refer below screenshot
Give prefix, number and number of digits as per your requirement.
Plz Mark my Solution as Accept and Give me thumbs up, if you find it Helpful.
Samaksh
Kalyani Jangam1
Hi @Rachel39
There is Number Maintenance table in servicenow in which it is autopopulate number in field. You can check once for your table like below
It is possible using business rule but in business rule it is not displayed when form load it will update once record insert.
The OOB number field doesnot works correctly, with this field even if the record is blank it increases to 1.
I need a ID incrementing to 1 which should compare if there is a last ID number ended with 105 then it should increment to +1 as 106
