Auto-populate functionality doesn't work on back-end and it shows empty field for the catalog form
jeffreygard1127
Hi guys, on our catalog form, I created 3 new fields
1. Select user
2. Department
3. Email Address
All fields are reference type and reference to sys_user table.
For the Department and Email address field, I used the functionality "Auto-Populate" and the dependent question is the "Select User"
It is working properly on the portal. Whoever I selected as user on the "Select user" field, it will just auto-populate the Department and Email field.
However, on the back-end, the Department and Email Address field is EMPTY
does anyone know how to fix this?
Ankur Bawiskar
@jeffreygard1127
If the variable type and the field type from where you are fetching are different then it won't work.
Department variable should be referring to cmn_department table and it should fetch value from Department field from sys_user.
Email variable should be single line text and not reference.
Please do the above changes and share feedback
Thank you @Ankur Bawiskar. It is working now.
@jeffreygard1127
Glad to help.
