Automate adding users to a Group if the group is assignment group
RichardSaunders
Hi, i have read lots of posts around automating this process but not quite the same requirements.
We have a Catalogue Request Item called - Add user to group - ServiceDeskOnline
This has two variable sets
Variable Set - SDO_Group
Variable - GroupName
Reference - sys_user_group
Variable Set - essAddUsers
Variable - essAccountUsers
List collector - sys-user
Providing the requested group has Assignment Group checked i would like them added automatically.
Would someone be able to provide steps to automate this?
Many Thanks
addUsersToGroup();
function addUsersToGroup()
  var myUsers = current.variables.essAccountUsers;
  //gs.log("//\\   list collector: " + myUsers);
  //gs.log("//\\ type of list collector: " + typeof myUsers);
  myUsers = myUsers.toString();
  //myUsers = myUsers.replace(/\s/g, '');
  //gs.log("//\\ type of myUsers: " + typeof myUsers);
  var myUsersInd = myUsers.split(",");
  //gs.log("//\\ splited part: " + myUsersInd);
  //gs.log("//\\ type of object : " + typeof myUsersInd);
  //gs.log("//\\ first element: " + myUsersInd[0]);
  var countUsers = myUsersInd.length;
  //gs.log("//\\ users count: " + countUsers);
  //gs.log("//\\ Group Name is :" +current.variables.GroupName.getDisplayValue());
  //gs.log(" initial variable list collector: " + myUsers);
  var existingMembers =   [];
  var retrive = new GlideRecord('sys_user_grmember');
  retrive.addQuery('group',current.variables.GroupName);
  retrive.query();
  while(retrive.next())
  existingMembers.push(retrive.user.toString());
  for(var i = 0 ; i <   countUsers ; i++)
  var arrUt = new ArrayUtil();
  var grp = new GlideRecord('sys_user_group');
  grp.get(current.variables.GroupName.toString());
  gs.log("//\\ grpName " + grp.sys_id + " " + grp.name + " " + grp.u_assignment_group);
  var member = new GlideRecord('sys_user');
  member.get(myUsersInd[i].toString());
  gs.log("//\\ memberRec " + member.sys_id + " " + member.user_name);
  var grMember = new GlideRecord('sys_user_grmember');
  if(arrUt.indexOf(existingMembers,myUsersInd[i].toString()) == -1)
  if(grp.u_assignment_group == true) // if u_assignment_group is checked, then directly add user to group without creating a catalog task
  grMember.initialize();
  grMember.group = current.variables.GroupName;
  grMember.user = myUsersInd[i];
  grMember.insert();
  gs.log("//\\ User " + myUsersInd[i] + " has been added to group   " + current.variables.GroupName);
  else   // create a catalog task for manual fulfillment for each user
  gs.log("//\\ Group is not an assignment group and hence creating task ");
  var ctsk = new GlideRecord('sc_task');
  ctsk.initialize();
  ctsk.request_item = current.sys_id;
  ctsk.assignment_group.setDisplayValue('Database');
  ctsk.short_description = " Check if user to be added to group or not";
  ctsk.description = "Please check for user " + member.user_name + " has to be added or not to Group " + current.variables.GroupName.getDisplayValue();
  ctsk.insert();
Hi Richard,
Above version is working and also made available in your developement instance.
It is working as expected. You can test it throughly.
18 REPLIES 18
var gr = new GlideRecord('sys_user_grmember');
gr.addQuery('group',current.variables.GroupName);
gr.addQuery('group.u_assignment_group',true); // check if group is assignment group as well
var count = 0;
while(gr.next())
      if(current.variables.essAccountUsers.toString()   == gr.user.toString()) // added the missing parenthesis here
                  gs.log("User already exists")
  count++;
if(count ==0)
    gr.initialize();
    gr.group = current.variables.GroupName;
  gr.user = current.variables.essAccountUsers;
  gr.insert();
  gs.log("User " + current.variables.essAccountUsers + " has been added to group   " + current.variables.GroupName);
I have corrected the line 08 based on the screenshot provided by you.
I agree with you, you wont require a catalog task here since it is kind of redundant.
Still, you may create it from process compliance point of view wherein, task will get auto-generated, it will have a work_notes auto populated based on the whether user has been added / already exists etc. but totally depends on how you want to set it up. Not the mandatory thing.
That's seems like a lot of work considering the way we implemented Our instance is heavily based on AD LDAP with a OU dedicated to SNow and user groups in that OU are synced to SNow so membership in a assignment group is automatic once that user is added to the group in AD.
Hi Jeffery,
If you are integrated with AD and managing users , groups and their membership as well via integration only, then you don't have to worry about manual membership management.
Sorry but I could not get your question. Could you please elaborate further on it?
Sorry if I wasn't clear, I had no question and was just offering a different method to achieve Richard's goal.
Okay, got it now.
You wanted to point towards AD integration to accomplish the same.
