Automate adding users to a Group if the group is assignment group
RichardSaunders
Hi, i have read lots of posts around automating this process but not quite the same requirements.
We have a Catalogue Request Item called - Add user to group - ServiceDeskOnline
This has two variable sets
Variable Set - SDO_Group
Variable - GroupName
Reference - sys_user_group
Variable Set - essAddUsers
Variable - essAccountUsers
List collector - sys-user
Providing the requested group has Assignment Group checked i would like them added automatically.
Would someone be able to provide steps to automate this?
Many Thanks
addUsersToGroup();
function addUsersToGroup()
  var myUsers = current.variables.essAccountUsers;
  //gs.log("//\\   list collector: " + myUsers);
  //gs.log("//\\ type of list collector: " + typeof myUsers);
  myUsers = myUsers.toString();
  //myUsers = myUsers.replace(/\s/g, '');
  //gs.log("//\\ type of myUsers: " + typeof myUsers);
  var myUsersInd = myUsers.split(",");
  //gs.log("//\\ splited part: " + myUsersInd);
  //gs.log("//\\ type of object : " + typeof myUsersInd);
  //gs.log("//\\ first element: " + myUsersInd[0]);
  var countUsers = myUsersInd.length;
  //gs.log("//\\ users count: " + countUsers);
  //gs.log("//\\ Group Name is :" +current.variables.GroupName.getDisplayValue());
  //gs.log(" initial variable list collector: " + myUsers);
  var existingMembers =   [];
  var retrive = new GlideRecord('sys_user_grmember');
  retrive.addQuery('group',current.variables.GroupName);
  retrive.query();
  while(retrive.next())
  existingMembers.push(retrive.user.toString());
  for(var i = 0 ; i <   countUsers ; i++)
  var arrUt = new ArrayUtil();
  var grp = new GlideRecord('sys_user_group');
  grp.get(current.variables.GroupName.toString());
  gs.log("//\\ grpName " + grp.sys_id + " " + grp.name + " " + grp.u_assignment_group);
  var member = new GlideRecord('sys_user');
  member.get(myUsersInd[i].toString());
  gs.log("//\\ memberRec " + member.sys_id + " " + member.user_name);
  var grMember = new GlideRecord('sys_user_grmember');
  if(arrUt.indexOf(existingMembers,myUsersInd[i].toString()) == -1)
  if(grp.u_assignment_group == true) // if u_assignment_group is checked, then directly add user to group without creating a catalog task
  grMember.initialize();
  grMember.group = current.variables.GroupName;
  grMember.user = myUsersInd[i];
  grMember.insert();
  gs.log("//\\ User " + myUsersInd[i] + " has been added to group   " + current.variables.GroupName);
  else   // create a catalog task for manual fulfillment for each user
  gs.log("//\\ Group is not an assignment group and hence creating task ");
  var ctsk = new GlideRecord('sc_task');
  ctsk.initialize();
  ctsk.request_item = current.sys_id;
  ctsk.assignment_group.setDisplayValue('Database');
  ctsk.short_description = " Check if user to be added to group or not";
  ctsk.description = "Please check for user " + member.user_name + " has to be added or not to Group " + current.variables.GroupName.getDisplayValue();
  ctsk.insert();
Hi Richard,
Above version is working and also made available in your developement instance.
It is working as expected. You can test it throughly.
18 REPLIES 18
var gr = new GlideRecord('sys_user_grmember');
  gr.addQuery('group',current.variables.GroupName);
  //gr.addQuery('group.u_assignment_group',true); // check if group is assignment group as well
  var count = 0;
  while(gr.next())
  if(myUsersInd[i].toString()   == gr.user.toString()) // added the missing parenthesis here
    gs.log("User already exists is a group")
    count++;
  if(count ==0)
    if(group.u_assignment_group == true) // if u_assignment_group is checked, then directly add user to group without creating a catalog task
      gr.initialize();
      gr.group = current.variables.GroupName;
      gr.user = myUsersInd[i];
      gr.insert();
      gs.log("User " + myUsersInd[i] + " has been added to group   " + current.variables.GroupName);
    ctsk.initialize();
    ctsk.assignment_group.setDisplayValue('Assignment Group Name should go here');
    ctsk.insert();
Hi Deepak,
Thanks again for taking time to look at this.
Unfortunately it doesn't appear to be working. It neither adds to the group or creates a task. i tried adding in a 5 sec timer before the script but have the same issue. Feel free to Skype me.
Hi Richard,
Can you check "Script log statements" and see if it has our log statement generated?
addUsersToGroup();
  retrive.query();
  grMember.insert();
  ctsk.initialize();
  ctsk.insert();
Hi Richard,
