background script to identify particular assignment group in all workflows and flow designers
sinu2
Hi
I need to identify the workflows and flow designers that are using particular assignment group- through background script. If anybody has the script kindly help here.
Aparna42
var uniqueRecords = {};
// Define the name of the user group you are looking for
var inputgroupName = agName; // Replace with the actual group name
// Create a new GlideRecord object for the 'sys_user_group' table
var igroupGr = new GlideRecord('sys_user_group');
// Add a query condition to search for the user group by name
igroupGr.addQuery('name', inputgroupName);
// Query the table
igroupGr.query();
if (igroupGr.next()) {
    // If a record is found, get the sys_id of the user group
    var inputAssignmentGroup = igroupGr.getValue('sys_id');
    gs.log('User Group Sys ID: ' + inputAssignmentGroup);
//var inputAssignmentGroup = '5573a0801b73e01050a8da02dd4bcb47'; // Your input assignment group value
var gr = new GlideRecord('sys_variable_value');
//variable=d7f2bd33c0a801650021da8ff242a081^valueISEMPTY^ORvalue=feba19191bdfa0545c4699fe034bcbfd
// Add query conditions
var qc = gr.addQuery('value', inputAssignmentGroup);
qc.addOrCondition('value', '');
gr.addQuery('variable', 'd7f2bd33c0a801650021da8ff242a081');
while (gr.next()) {
    var docKey = gr.getValue('document_key');
    //gs.log(docKey);
    var docKeyGr = new GlideRecord('wf_activity');
    if (docKeyGr.get(docKey)) {
        var workflowVersion = docKeyGr.getDisplayValue('workflow_version');
        if (workflowVersion) {
           // gs.log(workflowVersion);
            // Attempt to access vars fields: task_fulfillment_group or advanced_script
            var varsField = gr.getValue('value');
            //gs.log(varsField);
            if (varsField) {
                // Commented out logging
                //gs.log("varsField " + varsField);
                var taskFulfillmentGroup = docKeyGr.getDisplayValue('vars.var__m_38891b6f0a0a0b1e00efdfdd77602027.task_fulfillment_group');
                var groupName = taskFulfillmentGroup; // Replace with the actual group name
                var groupGr = new GlideRecord('sys_user_group');
                groupGr.addQuery('name', groupName);
                // Query the table
                groupGr.query();
                if (groupGr.next()) {
                    var groupSysId = groupGr.getValue('sys_id');
                    // gs.log('User Group Sys ID: ' + groupSysId);
                // gs.log("varsField " + taskFulfillmentGroup);
                if (groupSysId === inputAssignmentGroup) {
                    uniqueRecords[workflowVersion] = true;
                    // gs.log("Task Fulfillment Group: " + taskFulfillmentGroup);
                // Fallback to advanced_script if task_fulfillment_group is not present
                var advancedScript = docKeyGr.getDisplayValue('vars.var__m_38891b6f0a0a0b1e00efdfdd77602027.advanced_script');
                if (advancedScript) {
                    // Extract the assignment group from the advanced script
                    var match = advancedScript.match(/task\.assignment_group\s*=\s*['"]([^'"]+)['"]/);
                    if (match && match[1] === inputAssignmentGroup) {
                        // gs.log("Extracted Assignment Group: " + match[1]);
            // gs.log("Workflow version not found for Document Key: " + docKey);
        // gs.log("No record found for Document Key: " + docKey);
var uniqueArray = Object.keys(uniqueRecords);
 gs.log("Unique Workflow Versions: " + uniqueArray.join(", "));
// Optional: If you want to fetch the workflow names, you may need additional code here to map workflow versions to names.
Josh_Cooper
For Flow, it's harder because of the way ServiceNow stores it, but it IS stored.  This is something similar I used:
findGroups();
function findGroups(){
    var assignGroup = '';
    var getGroups = new GlideRecord('sys_variable_value');
    getGroups.addEncodedQuery('document!=wf_activity^ORdocument=NULL^document=sys_hub_action_instance^variableSTARTSWITHfiel^valueLIKEassignment_group=');
    getGroups.query();
    while(getGroups.next()){
        varSplit1 = getGroups.value.split(":");
        //varSplit2 = varSplit1[1].split(',');
        assignGroup = varSplit1[1];
        var getFlow = new GlideRecord('sys_hub_action_instance');
        getFlow.get(getGroups.document_key);
        gs.info('Flow: '+getFlow.flow.getDisplayValue()+" uses assignment group: "+assignGroup);
Be sure to change the StartsWith query to a Contains if you can't guarantee it's the first field set.
Geraldina Valer
Has anyone tried this? I have the same question.
We need a script that, using an assignment group, returns all the flows where it is used.
We queried the sys_hub_flow_component , sys_hub_action_instance_v2 , sys_variable_value tables, but were unable to obtain that data.
thanks!
