Before Query Business Rule is not working
Rajamouly
HI,
I am trying to restrict the incident records, when the user is tick on the check box  'Visible to HRIS team' and should be part of any of two assignment groups  "HRIS - Workday Support"  and "HRIS - iCIMS Support" .
Below is the Business Rule Written but it is not working.
(function executeRule(current, previous /*null when async*/) {
 visible= current.u_visible_to_hris_team;
  if(visible=='true'){
    if(gs.getUser().isMemberOf('HRIS - Workday Support')) {
current.addQuery('assignment_group.name','HRIS - Workday Support');
    else if (gs.getUser().isMemberOf('HRIS - iCIMS Support')){
current.addQuery('assignment_group.name','HRIS - iCIMS Support');
})(current, previous);
Note: The Business Rule is working if we remove the Check box condition "if(visible=='true')" ,  Please help me how should it make it work for Check box True condition.
11 REPLIES 11
@Rajamouly
just with conditions it will work
Ensure you give correct conditions for both
HI @Ankur Bawiskar
I crated a custom role 'HRIS_WD' same role i have assigned to two HRIS groups, created a new Read ACL on incident table with condition 'Visible to HRIS Team is True'  and if i logged in with HRIS user and tick the check box true, same INC is visible to all other ITIL users.
Please advise anything i am missing?
@Rajamouly
your query BR and table level READ ACL should be in sync
HI @Ankur Bawiskar
Sorry to trouble you again, i have enabled both BR and ACL but still no luck.
I removed the condition  if(visible=='true')  from BR, below is the BR script
    else if (gs.getUser().isMemberOf('HRIS - iCIMS Support')) {
Amit Gujarathi
HI @Rajamouly ,
I trust you are doing great.
Please refer below updated code:
  var visible = current.u_visible_to_hris_team;
  if (visible === 'true') {
    var assignmentGroup = current.assignment_group;
    if (assignmentGroup.nil()) {
      current.addQuery('assignment_group.nameIN', ['HRIS - Workday Support', 'HRIS - iCIMS Support']);
      var assignmentGroupName = assignmentGroup.name.toString();
      if (assignmentGroupName !== 'HRIS - Workday Support' && assignmentGroupName !== 'HRIS - iCIMS Support') {
Was this answer helpful?
Please consider marking it correct or helpful.
Your feedback helps us improve!
Thank you!
Amit Gujrathi
