Below script in nor working correctly
keval3
I have written below inbound email action script on sc_req_item table
by using that 2 request are created 1 with proper catalog item and another one in without catalog item please let me know what is issue in my script.
var cart = new Cart();
    // // add in cart, substitute your catalog item sys_id
    var item = cart.addItem('49dd78a3db427c50eeb8026dd3961902');
     cart.setVariable(item, 'description', email.body);
     cart.setVariable(item, 'contact_type', 'email');
     cart.setVariable(item, 'requested_for', '3336eb92dba9dc10a73ddf0bd39619bd');
    cart.setVariable(item, 'subject', email.subject);
    var rc = cart.placeOrder();
  Thanks & Regards
KP
Hi @keval3 ,
Use only one time to generate the RITM. Use below code exactly.
You can run this in background script as well, just to check that it create only one RITM.
Let me know if still face any issue.
var id = GlideGuid.generate(null);
    var cart = new Cart(id);
    cart.setVariable(item, 'sub_heads', 'nurture_business');
    var request = cart.placeOrder();
And make sure your inbound action is executing only one time.
In this i have explained that how you will connect with third party tool like SCCM , JAMF, SolarWinds and Vmware Workspace using service graph connect in ServiceNow. purpose for integrating these tool to bring the assets information in ServiceNow. For document please visit: ...
Hi Ranjay,
I have used same code now still 2 tickets created. 1 with items and another one is blank.
(function runAction( /*GlideRecord*/ current, /*GlideRecord*/ event, /*EmailWrapper*/ email, /*ScopedEmailLogger*/ logger, /*EmailClassifier*/ classifier) {
    // Implement email action here
})(current, event, email, logger, classifier);
Hi Ranjay,
I have tried same code in test instance in that blank tickets are created. items are not getting populated. please help me resolved my issue. kindly find below screen snap.
(function runAction(/*GlideRecord*/ current, /*GlideRecord*/ event, /*EmailWrapper*/ email, /*ScopedEmailLogger*/ logger, /*EmailClassifier*/ classifier) {
