bringing list of Incidents onto a Problem Report
mrswann
Greetings!
We have a requirement for a Problem Report. There is a field called "related_incidents" which contains a count of related Incidents.
There is a related list on the Problem form of all the related incidents.
Is there anyway to pull a list of these incident numbers, into a column, for reporting against Problems?
16 REPLIES 16
Thanks John. I appreciate you taking the time along with Blaze to try and help. Unfortunately these still do not solve the particular request but I think it should be my job to push back slightly and better understand what/why etc as TBH it is probably a slightly whimsical requirement we can solve in a different / better way.
Ok, maybe I don't quite get what is being asked for either, could you be a little more specific. That is a way to pull a list of INTs related to a PRB, If your team is looking for a way to "expand" the associated INT count to show the INT numbers, That is not possible off that calculation. What is the value your team is looking for?
Not sure if I'm getting what you are after.
You want a list report.. that I get
Should each row contain a problem number and an incident number? is that what you are after?
//Göran
mrswann
so in one column on one row: for each problem , a list of the incident ref numbers associated to that problem (in one field)
That is an odd request, I'm pretty sure it is not possible in the reporting tools, you could maybe develop a background script that could do that, or export to Excel and concatenate the results. What does the requester think the value of such a report would be, what will the INT# detail help them to do?
