‎10-13-2022 10:38 PM - edited ‎10-13-2022 10:57 PM
Create a before insert business rule that checks will check to see if the logged in user is attempting to insert the role of admin or security_admin into a record on the sys_user table or sys_user_group table. If so the logged in user must be one of the following
SONALI(S12365)
PHANI(P67543)
PRIYA(P6539)
If not abort the action and display a message "You are not authorized to perform this action. If you need to provide admin or security admin access to a user you must submit the following request in the ServiceNow Production instance
‎10-13-2022 11:06 PM
Ok. So you will have to create an onInsert Before Business rule in the sys_user_has_role table. I should be pretty simple.
In the BR condition, you can specify the roles, for ex, Role = admin OR Role = security_admin && User!=SONALI && User!=Phani && User!=PRIYA
And in the 2nd Tab 'Set Values', you can select action to Abort with the abort message.
‎10-14-2022 12:03 AM
Looks good to me
‎10-14-2022 12:27 AM
Thanks. Its working:)
‎10-14-2022 12:30 AM
Awesome 🙂
