By using fix script we need add roles to the groups .
aarya1
Giga Contributor
Hi
My requirement is to add  one role to particular groups by using fix script.
There are some filter conditions while querying the group table , below are the filter conditions
Group should be active, group should be itil, and group should be non working group.
By using those conditions we need to get that particular groups if those conditions are matched then we need to check that particular groups has sn_role , if this role is there to that groups then dont do any thing , if that role is not there to that groups then add sn_role.
This is my requirement.
Please suggest with your answers.
Thanks in advance
Aarya
something like this; enhance it
addRole();
function addRole(){
	try{
		var gr = new GlideRecord("sys_user_group");
		gr.addEncodedQuery("Your Query"); // give your query here
		while(gr.next()) {
			var gr1 = new GlideRecord("sys_group_has_role");
			gr1.addQuery("group", gr.getUniqueValue());
			gr1.addQuery("role.name", "sn_role"); // give exact role name here
			gr1.query();
			if (!gr1.hasNext()) {
				gr1.initialize();
				gr1.group = gr.getUniqueValue();
				gr1.setDisplayValue('role','sn_role'); // give exact role name here
				gr1.insert();
	catch(ex){
		gs.info(ex);
16 REPLIES 16
addRole();
function addRole(){
	try{
		while(gr.next()) {
			gr1.query();
				gr1.initialize();
				gr1.insert();
	catch(ex){
		gs.info(ex);
Hi @Ankur Bawiskar
Thanks for your help
I will try that script
Aarya
@aarya
Sure. Do keep posted.
Hi @Ankur Bawiskar
Your script helped me a lot and i did changes  as per my requirement .
Now its working
Thanks @Ankur Bawiskar
Aarya
Hi @Ankur Can we add 3 roles to single group by using fix script Regards Aarya
