Calculate time difference in minutes
Santhana Rajhan
I want a field to display the difference between two times in minutes.
Eg: Business Duration = 136
Hello Santhana
Please try below. g_form doesnot work server side
(function calculatedFieldValue(current) {
var dateString1 = new GlideDateTime(current.begin); //make sure variable name is begin
var dateString2 = new GlideDateTime(current.end); // make sure variable name is end
var diffSeconds = gs.dateDiff(dateString1, dateString2, true);
diffMins = diffSeconds/60;
return Math.round(diffMins);   // return the calculated value
})(current);
21 REPLIES 21
I am unable to add this attribute.
An admin would need to add the attribute.   If you switch over to the 'advanced' view of the dictionary record you can just drop max_unit=minutes into the attributes field.
Something like this?
Back up a step.   In the dictionary record, in the 'related links' section right above the related lists, you should see an 'Advanced View' link.   Click that.   When the form reloads you'll see an 'Attributes' field.
This one too didnt work
