Calculate time difference in minutes
Santhana Rajhan
I want a field to display the difference between two times in minutes.
Eg: Business Duration = 136
Hello Santhana
Please try below. g_form doesnot work server side
(function calculatedFieldValue(current) {
var dateString1 = new GlideDateTime(current.begin); //make sure variable name is begin
var dateString2 = new GlideDateTime(current.end); // make sure variable name is end
var diffSeconds = gs.dateDiff(dateString1, dateString2, true);
diffMins = diffSeconds/60;
return Math.round(diffMins);   // return the calculated value
})(current);
21 REPLIES 21
The rule didnt work. The type of the Business Duration field is an integer. Is that a problem?
vikkyk
Giga Contributor
To calculate the time difference between two Date/Time fields in minutes, use a GlideDateTime difference and convert it to minutes:
var gdtStart = new GlideDateTime(current.begin);
var gdtEnd = new GlideDateTime(current.end);
// Difference in milliseconds
var diff = gdtEnd.getNumericValue() - gdtStart.getNumericValue();
// Convert ms → minutes
var minutes = diff / 1000 / 60;
current.u_business_duration = minutes;
Begin: 2017-12-26 07:39:52
End: 2017-12-26 09:55:52
Difference: 2 hours 16 minutes = 136 minutes
