Calculate total cost and set in variable using catalog client script
Rajavardhini
Hi Team,
I have 4 different variables to enter the cost.
Onchange each variable calculate the total field and update in the total cost.
I have written below code but throwing NAN error.
    var numnericVal = g_form.getValue('estimated_cost_rail_update');
    if (isNaN(numnericVal)) // check if value is not numeric
        g_form.setValue('estimated_cost_rail_update', ''); // Set the field to empty
        g_form.showFieldMsg('estimated_cost_rail_update', 'Please enter numeric values', 'error');
        var estimated_air = g_form.getValue("estimated_cost_air");
        var estimated_rail = g_form.getValue("estimated_cost_rail_update");
        var estimated_car = g_form.getValue("estimated_cost_taxi_upate");
        var estimated_hotel = g_form.getValue("estimated_cost_hotel_update");
        var total=parseInt(estimated_air)+parseInt(estimated_rail)+parseInt(estimated_car)+parseInt(estimated_hotel);
        //var total = parseFloat(estimated_air) + parseFloat(estimated_rail) + parseFloat(estimated_car) + parseFloat(estimated_hotel);
        g_form.setValue("estimated_cost3", total);
        alert(parseInt(total));
Please help if any mistake is here.
Vardhini
Najmuddin Mohd
Hi @Rajavardhini ,
I have checked this. Yes, this issue happens when you changing the field values on which you have written on-change client script and other field values are empty.
To avoid this, I had retrieved values as Zero(0), if the field values are empty else take the value present in it.
var estimated_air = (g_form.getValue("estimated_cost_air") != '') ? g_form.getValue('estimated_cost_air') : 0;
Use the above ternary operation for all the values.
If this information helps you, Kindly mark this post as Helpful and Accept the solution.
Najmuddin.
