Is two-way synchronization between two catalog variables technically supported inside Service Portal
profile
Is two-way synchronization between two catalog variables technically supported inside Service Portal.
I have two catalog variables inside a variable set:
euid (text)
associate_name_common (reference to sys_user)
Both fields need to stay synchronized:
When the user enters an EUID, the script should populate associate_name_common.
When the user selects associate_name_common, the script should populate EUID. This is not works correctly in Maintain Item view and Service Portal (Try It)
Important details:
Both variables are on a variable set, used on 25 items
Using onChange Catalog Client Scripts
Using GlideAjax + Script Include
Even with flags like:
g_form.setParameter('sysparm_skip_euid_update')
window._lock
g_scratchpad
isLoading
→ the loop continues in Service Portal and Maintain Item view(platform ui) view.
I want solution to this problem. Please, anyone help me out from this problem
Below I am attaching my Catalog Client Scripts and Script Include.
I have tried by creating all the server side script include code in one script include itself it doesn't work
And both script include code are Client callable.
var UserLookupAjax = Class.create();
UserLookupAjax.prototype = Object.extendsObject(AbstractAjaxProcessor,
getUserByEUID: function() {
var euid = this.getParameter('sysparm_euid');
if (!euid) {
return '';
var user = new GlideRecord('sys_user');
user.addQuery('u_euid', euid);
user.query();
if (user.next()) {
return user.sys_id;
return '';
type: 'UserLookupAjax'
var UserLookupEUID = Class.create();
UserLookupEUID.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getEUIDByUserSysId: function() {
var sysId = this.getParameter('sysparm_user_sysid');
if(!sysId) {
return '';
if(user.get(sysId)) {
return user.u_euid.toString();
return '';
type: 'UserLookupEUID'
function onChange (control, oldValue, newValue, isLoading) {
// Type appropriate comment here, and begin script below
var ga = new GlideAjax('UserLookupEUID');
ga.addParam('sysparm_name', 'getEUIDByUserSysId');
ga.addParam('sysparm_user_sysid', newValue);
ga.getXMLAnswer (function(response) {
if (response) {
g_form.setValue('euid', response);
g_form.setValue('euid', '');
var ga = new GlideAjax ('UserLookupAjax');
ga.addParam('sysparm_name', 'getUserByEUID');
ga.addParam('sysparm_euid', newValue);
if (response) {
g_form.setValue('associate_name_common', response);
g_form.setValue('associate_name_common', '');
Brad Bowman
Mega Patron
One way to attempt this is in both client scripts, within the if (response) block or adding AND (&&) to this if statement, also do a getValue on the field that's about to be changed, and don't setValue if it = response.
Mark Manders
Why not only use the reference field? Since you can only search for people that are in the system (otherwise they can't be in sync). If you use the look up, you have the fields to search for the user. Then you can just use 'auto populate' to fill the string field.
Mark
