Calculate two fields and autopopulate sum
bindu999
    I'm using client script to calculate the value of a+b and get total sum value in the single line text box. This script is not working for me. can you help me
 I'm using 2 select box'es
a Select Box has option yes or no  (Yes value as 10 ; No Value as 5)
b Select Box has option yes or no (Yes value as 10 ; No Value as 5)
I'm using C as a single line text box I need to get the score of what the user selects.
If Select Yes in A; Yes in B;
It should autopopulate C as 10
Client Script:
var xyz ='';
var X = g_form.getValue('a');
alert('a');
var Y = g_form.getValue('b');
var Z = g_form.getValue('c');
xyz = X+Y+Z;
g_form.setValue('score', xyz);
alert('xyz');
Please Help!!
Thank you!!!
Hi @bindu999
Finally Im here with an answer,
That is you have to write two Onchange client scripts() for two variables ie, var1,var2.
I have tried in my PDI its working as you expected.
Im posting the screenshots as well..
Let me know if you still facing difficulty..
Code:
Onchange()
if (newValue != oldValue && newValue != '') {
var f1 = g_form.getValue('variable1');
var f2 = g_form.getValue('variable2');
if (f1 != '' && f2 != '') {
g_form.setValue('result', parseInt(f1) + parseInt(f2));
PFA:
Murthy
Murthy
21 REPLIES 21
Can you confirm which field have you selected for onChange client script?
Can you update your onChange client script to :
    var X = g_form.getValue('variables.a');
    var Y = g_form.getValue('variables.b');
    var Z = g_form.getValue('variables.c');
    var xyz = parseInt(X) + parseInt(Y) + parseInt(Z);
    alert(xyz);
Sure, one sec
Yeah I tried this script too, but it didn't work. Not sure why
I have to generate risk, i will give questionnaire to end user. He will fill with the options. I need to generate risk score depending on options they select.
A Select Box with options None, Yes, No  (Yes Value 10, No Value 5)
B Select Box with options None, Yes, No  (Yes Value 10, No Value 5)
C Select Box with options None, Yes, No  (Yes Value 10, No Value 5)
Score Single Line Text box
Consider the following points:
Variable name seems empty on client script form. Try selecting field a
Is your client script changed from onLoad to onChange? if so then make this inactive and create a new one.
Uncheck Apply to Requested Items
Uncheck Apply to catalog tasks
And use the following script:
    g_form.setValue('variables.score', xyz);
    alert(xyz);
Make sure you're providing the field names correctly.
