Calculate two fields and autopopulate sum
bindu999
    I'm using client script to calculate the value of a+b and get total sum value in the single line text box. This script is not working for me. can you help me
 I'm using 2 select box'es
a Select Box has option yes or no  (Yes value as 10 ; No Value as 5)
b Select Box has option yes or no (Yes value as 10 ; No Value as 5)
I'm using C as a single line text box I need to get the score of what the user selects.
If Select Yes in A; Yes in B;
It should autopopulate C as 10
Client Script:
var xyz ='';
var X = g_form.getValue('a');
alert('a');
var Y = g_form.getValue('b');
var Z = g_form.getValue('c');
xyz = X+Y+Z;
g_form.setValue('score', xyz);
alert('xyz');
Please Help!!
Thank you!!!
Hi @bindu999
Finally Im here with an answer,
That is you have to write two Onchange client scripts() for two variables ie, var1,var2.
I have tried in my PDI its working as you expected.
Im posting the screenshots as well..
Let me know if you still facing difficulty..
Code:
Onchange()
if (newValue != oldValue && newValue != '') {
var f1 = g_form.getValue('variable1');
var f2 = g_form.getValue('variable2');
if (f1 != '' && f2 != '') {
g_form.setValue('result', parseInt(f1) + parseInt(f2));
PFA:
Murthy
Murthy
21 REPLIES 21
One more point:
Your are changing three fields a, b, c and you are writing onChange client script on 1 field.
It will only work onChange of one field. You'll have to write 3 same client script if you want to get sum of all these 3 fields in real time.
Better way for this will be to write an After update Business Rule and set the field once you update the form:
Your BR script will look like :
var total_score = parseInt(current.a) + parseInt(current.b) + parseInt(current.c);
current.setValue('score',total_score )
bindu999
Thank you each and everyone for your valuable inputs.
