Call an array in the Catalog Client Script
xhensilahad
Good afternoon,
I am trying to pass an array from a Script Inlcude to a Catalog Client Script.
I have tested my Script Include at it is returning the correct values, as a coma separated list.
I want to call this list in my Catalog Client Script, and hide all these variables.
Please can you help me with my Catalog Client Script.
Script Include:
(Client Callable is true)
var VariableTypeChecker = Class.create();
VariableTypeChecker.prototype = {
    getVariableTypes: function(ritmSysId) {
    var results = [];
        var ritm = new GlideRecord('sc_req_item');
        if (ritm.get(ritmSysId)) {
            var variables = ritm.variables.getElements();
            for (var i = 0; i < variables.length; i++) {
                var question = variables[i].getQuestion(); // Access variable metadata
                if (question) {
                    var name = question.getName();
                    var type = question.getType();
                    var value = variables[i].getValue();
                    // Check for checkbox type (type 7) and value 'false'
                    if (type === '7' && value === 'false') {
                        results.push(name); /
        return results.toString();
    type: 'VariableTypeChecker'
function onLoad() {
   var ritmSysId = g_form.getUniqueValue();
    var ga = new GlideAjax('VariableTypeChecker');
    ga.addParam('sysparm_name', 'getVariableTypes');
    ga.addParam('sysparm_ritmSysId', ritmSysId);
    ga.getXMLAnswer(hideVariables);
    function hideVariables(response) {
        var answer = response;
        var variableNames = JSON.parse(answer);
        for (var i = 0; i < variableNames.length; i++) {
        var variableName = variableNames[i];
        g_form.setDisplay(variableName, false);
Thank you
Hi Ashul,
The requirement is:
After a Request is submitted, all the checkboxes that were not checked, have to be hidden from the RITM and the SCTASK.
To identify these variables, I have added the condition type=7 (which is a checkbox) and value if 'false' in the Script Include.
I want to pull this variables in my Catalog Client Script, and hide them from the RITM and SCTASK.
Thank you
Hi Anshul,
I need to hide the unchecked variables from the RITM after the request has been submitted.
