Call existing Flows in a new Flow depending upon choice selection
08-25-2025 03:39 AM
I've 2 existing catalog items for Add users in a group and Remove Users from a group. And corresponding 2 Flows are there.
As per a new requirement I'm building a new Catalog item where I'm asking the end user to Add or Remove user from that group by using choice variable. (User has to select any one of the choice open Add or Remove).
Depending upon the selection of Radio button, I want to trigger the Flow. (Utilize the existing Flow)
Hence, I want to build a new Flow where it'll check the User's selection Add or Remove. And depending upon the selection, How I can call the existing flows?
Also, What are the prerequisites I need to take care.
09-18-2025 11:30 PM
Hope you are doing good.
