can someone help me to userstand UI action how its working client and server side together with example ..?
s_kumar
Mega Contributor
Request
zica
Giga Guru
Okay perfect,
Here is a screenshot that shows the parameters of the UI action, Please do the same
Do not forget to put the action name, check client to true, and put the function name on Onclick()
Capture d
HEre is the script :
function reopenIncidentTest(){
      if (g_form.getValue('comments') == '') {
              //Remove any existing field message, set comments mandatory, and show a new field message
              try {
                    g_form.hideFieldMsg('comments');
              } catch(e) {}
                    g_form.setMandatory('comments', true);
                    g_form.showFieldMsg('comments','Reason is required when reopening an incident','error');
                      return false;   //Abort submission
      //Call the UI Action and skip the 'onclick' function
      gsftSubmit(null, g_form.getFormElement(), 'incident_reopen_test'); //MUST call the 'Action name' set in this UI Action
//Code that runs without 'onclick'
//Ensure call to server-side function with no browser errors
if (typeof window == 'undefined')
      serverReject();
function serverReject(){
      current.state = 2;
      current.update();
31 REPLIES 31
zica
Giga Guru
Are you working on incident form ? or another form ?
s_kumar
Mega Contributor
thanks Zic..
I am working on incident form ,,
but its not changing the state
FYI...
i have created a table which is in different Application ... and there only i have created this UI Action on Table 'incident'   to change the state but its not working.
in last reply to Arnab i have sent my full code...
Hi Sandeep,
I believe it is because the value of the "State" field in the incident table is "incident_state" and not "state" which you are using in this line :
current.state = '2';
use current.incident_state = 2 ;   this will work I am sure. this is also mentioned in the code i have posted for my Reopen Incident button. See the screenshot.
Please let me know if your problem still persists.
Arnab
Please mark Correct/Helpful according to the worthiness of my solution. Happy Working !
Hi Sandeep,
Did you try my solution of changing the line current.state = '2' ; to current.incident_state = 2 ;       ???
Let me know your result on trying this line with my code.
Arnab
s_kumar
Mega Contributor
yeah   Arnab...
i have tried this also ..but its not changing the state...
after solution Zic gave latest one ...i am able to execute it but its opening new incident instead of changing the state of existing one.
