Can we pass display value for reference variable while submitting request via OOB API
Kumar4999
Currently while submitting the service catalog request using OOB API, When I am passing the sys_id in Reference type of variable the value is taking in the requst as expected.
But if we pass the display value reference field is taking as empty, is there a way we can use Display value in Reference type of variable while submitting the Service Catalog Request via SR OOb API?
API: /api/sn_sc/servicecatalog/items/{sys_id}/order_now
Example: If I like to select a user in reference filed which referred to User table. Is there a way I can pass the user id or Display name instead of user sys_id while ordering the catalog item similar to table APIs?
"sysparm_quantity": "1",
"sysparm_requested_for":"userid",
"sysparm_no_validation": "true",
"variables":
"test_user":"edscksacsaksaijd334b1cvdsavgasi"
12 REPLIES 12
Kumar4999
Hi @Ankur Bawiskar,
Could youy please clarify this doubte if possible.
Ankur Bawiskar
@Kumar4999
should work when you include this parameter in the URL i.e. REST endpoint.
sysparm_display_value=true
@Ankur Bawiskar ,
Thank you for quick response,
But my doubte is, Is there a way we can pass Display name as variable value in Payload for reference fields?
Currently it only accepting sys_id.
Example:
Currently this is working -
"variables":
Is there a way we can pass the Display value like below for reference fields?
"variables":
"test_user":"Kumar 4999"
@Kumar4999
I already told it's possible.
just include the sysparm_display=true in query parameter when you hit the endpoint
screenshot I already shared
@Ankur Bawiskar ,
Tried that but value not inserting even after using "sysparm_display_value=true"
Request created but user reference value not get inserted
Could you please suggest any other approach or am I doing it wrongly..
Kumar
