Can we pass display value for reference variable while submitting request via OOB API
11-24-2022 11:13 PM
Currently while submitting the service catalog request using OOB API, When I am passing the sys_id in Reference type of variable the value is taking in the requst as expected.
But if we pass the display value reference field is taking as empty, is there a way we can use Display value in Reference type of variable while submitting the Service Catalog Request via SR OOb API?
API: /api/sn_sc/servicecatalog/items/{sys_id}/order_now
Example: If I like to select a user in reference filed which referred to User table. Is there a way I can pass the user id or Display name instead of user sys_id while ordering the catalog item similar to table APIs?
11-28-2022 10:27 PM
you should be passing the name and not userid
whatever value is present in the name field on sys_user -> set that in API
11-28-2022 10:34 PM
Tried the same but still not working
Name field value
POSTMAN call using name value
Still value not inserting
Kumar
04-10-2025 06:02 AM
Have you found any solution for this issue passing the display value of an reference variable.
