Cancel workflow using RITM
Snow Tomcal
Hi, I am trying to create a business rule that is triggered when a field is changed in a certain table.
The business rule is supposed to cancel the workflow running on a specific request that uses the record.
So the "current" is the record in the table which field I changed. The record also has a reference field to the RITM, so I tried to use it and stop the workflow running from the RITM. I get the error "input argument to Workflow Script API is not valid GlideRecord. Creating default current".
Adding my script:
    var ritm = new GlideRecord('sc_req_item');
    ritm.addQuery('number', current.u_request_number);
    ritm.query();
    var workflow = new Workflow();
    workflow.cancel(ritm);
})(current, previous)
also tried canceling the context, also gave me the same error.
Anyone have any ideas? Thanks! 🙂
@Snow Tomcal i think i got the issue we are comparing with number but we need to compare with sys_id as you are storing the RITM in the reference field so try this below script
    ritm.addQuery('sys_id', current.u_request_number);
    ritm.query();
if(ritm.next())
    var workflow = new global.Workflow();
Hope this helps
Mark the answer correct if this helps you
Ashish21
Giga Expert
Please find below hyperlink:
https://community.servicenow.com/community?id=community_question&sys_id=a57a47e9db5cdbc01dcaf3231f9619b8
Please mark this correct or helpful.
