Catalog Builder Record Producer - How to define assignment group for record generated?
06-18-2024 11:41 AM
Using standard Record Producer we have the ability to script the assignment group for records created. How do we acheive this when using Catalog Builder and Record Producers?
Using Catalog Builder Record Producer I can define a Destination for the record but no Assignment Group..
Any one here have experience with CB?
06-19-2024 12:23 PM
Agree @Mark Nguyen
You can log this as an Idea and let SN evaluate it and return to you.
07-22-2025 03:48 PM
I haven't looked into this yet, but that seems crazy - enabling citizen development only to then require hands-on involvement from a resolver group just to update the script section?
When I was building our catalog item templates in Catalog Builder, I was able to modify the builder to display fields that aren’t available out of the box. I assume we could do something similar to expose the Template picker (i.e., Record Producer > Generated Record Data > Template). If we can show that, we could simply create a few templates that assign the producer to the appropriate assignment group.
11-05-2025 01:38 PM
A bit late to the party, but you absolutely can do that within Catalog Builder.
You just need to create a variable (question) pointing to group table, define the group you want as default value, map to assignment_group and then hide the variable.
