Catalog Client Script issue with clearValue() and showFieldMsg() in London
Matthew Glenn
Just upgrade my DEV instance from Jakarta 8b to London P1H1 and am having an issue I can't quite figure out
In both our DEV and PROD instances, I have the following snippet of code in an onChange Catalog Client Script
function displayMessage(){
	getMessage("generic message goes here",function(msg){
		g_form.clearValue("field_name");
		g_form.showFieldMsg("field_name", msg, "error");
This snippet works without issue in PROD (still on Jakarta), however, it doesn't work in DEV (now on London). If I comment out either the clearValue() or showFieldMsg() calls, the script runs without issue. When I attempt to let them run together, clearValue() works maybe 10% of the time, and if it does it's only on the first onChange event after the page load.
No console errors to speak of and I don't see anything in published known errors.
Has anyone else experienced this?
Mike Patel
Tera Sage
try setValue instead of clear
g_form.setValue("field_name", '');
Same outcome, unfortunately. Works if I remove showFieldMsg(), but not when used together
g_form.setValue("field_name", ''); or g_form.clearValue("field_name"); neither works in combination with g_form.showFieldMsg() or g_form.showErrorMsg() or alert();
Vaiju
Giga Contributor
Hello Team,
Just FYI.
In London version they have introduced 2 new fields on variable set form ;
  1. “Internal name” : We need to use this field value in all scripts instead of “Title” field value.
  2. “Type” : Variable set type as “Single Row” and “Multi Row”.
In all present scripts we used variable set “Title” field value, I will replace it with “Internal name” field value.
https://docs.servicenow.com/bundle/london-it-service-management/page/product/service-catalog-managem...
Best regards,
Vaijanath Shintre
