Catalog - How to set the use of a cart
‎06-02-2017 12:22 AM
We are in the process of creating a new service catalog.
Everything is running fine, but I am still battling in order to understand how to use the "2 steps" Cart.
We have another catalog using this cart, and it seems that the cart execution is related to a special field on each article, as a "true/false" value. Once set to true on an article, the request process will display the cart.
I'd like to be able to understand which "process" is calling this value as true/false, in order to create a new field.
Thank you,
Julian
Service Catalog
‎06-02-2017 06:15 AM
Thank you for your answer.
Unfortunately, unchecking "Use cart layout" is not changing anything.
I also tried to use "cart" reference field, but I don't get what it does reference to.
We have multiple catalogs. I guess we are not the only ones
Some are using the "normal" checkout, creating a REQ and RITMs when checking out the cart. Let's call them "CatA", "CatB" and "CatC".
One is using the "two-steps" checkout process, allowing to add infos like delivery address, etc... We created a field (true/false) related to this catalog. Let's call it "CatD", and "fieldD".
We created a new catalog, and we are looking for getting it to use the "two-steps" checkout process. Let's call it "CatE"
If I check the created field "fieldD" on a field of this new catalog "CatE", the "two-steps" checkout process is then applied.
So yes, it would be a "workaround", but as this "fieldD" name is quite related to the catalog "CatD" name, it's not really practical. Plus it would be nice to understand how it does actually work
Julian Christnacher
