Catalog item- How to call values in Drop down variable via system property
03-18-2025 07:21 AM
Hello Experts,
I have got a use case scenario where we required to populate values in a drop down variable in a catalog item. And those values should be coming via system property. Field is depended on another drop down.
Thanks in advance
Service Catalog
03-18-2025 08:00 AM
Please try the below steps.
1. Create System Properties: Define a system property with the values for the dropdown.
2. Create a Script Include: Write a Script Include to fetch the values from the system property.
3. Create a Catalog Client Script: Create a Client Script that triggers on change of the primary dropdown and populates the dependent dropdown with values fetched from the Script Include.
4. Configure Catalog Item Variables: Ensure you have two dropdown variables in your catalog item - one primary and one dependent.
Keerthi
03-18-2025 09:05 PM
why to have system property? choices needs to be there in choices table
what's the business requirement for this?
03-18-2025 09:26 PM
Hi @Kamini07 , It is not possible with multiple choice, instead choose Select Box, then
In the onLoad catalog client script -
var ga = new GlideAjax('ClientSideCall');
ga.addParam('sysparm_name', 'getProperty');
ga.getXML(getP);
function getP(response) {
var arr = answer.split(',');
for (var i = 0; i < arr.length; i++) {
g_form.addOption('drop_down', i, arr[i], i);
}In the Glide AJAX enabled script Include -
var ClientSideCall = Class.create();
ClientSideCall.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getProperty:function(){
return gs.getProperty('drop.down.sys.property');
type: 'ClientSideCall'
